I have a 1996 SEA
doo GTX, when I start the engine I have to keep choking out the motor to purge excess fuel from the back cylinder.
Evenutauly the engine will run properly and I can go down the river. The process takes about ten minutes of choking the engine. Each time I choke it I can go a little further. When the engine operates properly I can run for a long time. When I stop for more than 5 minutes I have to choke a few times and it streightens out. Sometimes after I am able to go down the river the engine will cough a few times but not stall. I was told that I have possibly a pop off problem with the carb or I have a o ring problem with the crank and It is leaking oil on the intake throuth the rotary valve shaft. I'm in the process of checking the pop off pressure. I converted the ski to a fuel premix, I disconnected the oil injection system. Any Ideas? When I start the engine out of the water on the garden hose, It runs for about 30 seconds before It loads up and starts heavy smoking and not running properly. Before I choke it out it won't rev up, I choke it out restart it and it will run for 1 minute before I have to repeat the process. I have a feeling I may be installing a SBT rebuild.
