Results 1 to 6 of 6
    Mar 2011
    Talahassee Florida
    5
    Default Sea-Doo Start/Stop switch cover replacement - how to install....
    Hello,
    I recently purchased two of the Sea-Doo start/stop switch red rubber covers.
    How do I replace them?
    Can the switch itself be serviced/cleaned out?
    I can't find any instructions on the site or in the forum.
    21,545
    Default Re: Sea-Doo Start/Stop switch cover replacement - how to install....
    to replace the old red button just work the old crud out of the grove with a small straight blade screwdriver and then carefully work the new button into the grove.
    Mar 2011
    Talahassee Florida
    5
    Do I need to take the switch cover off the handle bar or do this from the front (where you press the button)?
    21,545
    nope just work it out as it sits on the handle bar, much more simple then you are expecting.
    Mar 2011
    Talahassee Florida
    5
    You are correct....I was making this into a job, but it is the easiest thing I have done to the ski so far. I don't know if it could be any easier.
    The old cover just pulled out and I was able to just slide the new one into place, from the outside. I didn't have to take anything apart. WOW!
    Thank you for your help. Without it, I would have taken the thing apart to put this in place :)
    21,545
    Glad I could help.
    Regards,
    Tom
  1. 95 WR1100 start/stop switch problem
    By sotoflex in forum Yamaha
    Last Post: 09-02-2005, 06:45 PM
  2. start/stop switch
    By cerv96xp in forum Sea-Doo
    Last Post: 09-23-2003, 12:27 PM
  3. start/stop switch problems
    By bunny in forum Yamaha
    Last Post: 12-12-2001, 09:44 AM
  4. Start/Stop Switch Box
    By mreinke in forum Yamaha
    Last Post: 08-03-2001, 05:14 PM
