Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Sep 2003
    10
    Post
    I have a 97'gsx that starts very slow(starter does not turn over like it use to). When ski does start, does not stay running well and does not get over about 4300rps..not over about 30mph. Alot of water got in the hull at 1 time and has not been right since. if riding and hit bumps(large wakes) ski will tend go go into the 35-40mph..but will loose speed again. It also has very rough idleing. I just changed the plugs and has new gas. Whan may my problem be? Please any info would be helpful. Thanks
    21,551
    Post
    You need to not start it again, and do a compression check. I think you will find some damage and I would guess it's time to tear the motor down for inspection.
    Aug 2003
    queens
    60
    Post
    one thing it is possible your rave valve are dirty try to clean it check this site http://saldman.tripod.com/rave_valve/rave.html the should be clean every 50 hours
    [ September 02, 2003, 04:37 PM: Message edited by: roberto ]
    Sep 2003
    10
    Post
    could it be anything with the carburators or fuel problem since i can hit heavy wakes and the rpms and speed will increase? could the water be in the system anywhere. if i break down the engine what am i looking 4? Rebuild the carbs, clean them or anything..kinda at a loss of ideas...thanks
    21,551
    Post
    I'm thinking more like internal damage, and loss of power. You may have a bearing (or more) that are now shot, giving you the extra drag while starting - and top-end damage giving you the loss of power. A compression check should have been the first thing to do, as it can tell you if you need to stop and rebuild from the start.
    Aug 2003
    queens
    60
    Post
    it is hard to diagnoste from here but you have to check for comon sense and see
    Feb 2001
    Glendora, Ca.
    5,204
    Post
    Might even be a bad rectifier.
    Bill O'Neal WCM
  8. #8
    Sep 2003
    10
    Post
    what kinda probs would a bad rectifer show..how do i test to see if it is bad? Thanks...also the ski when it ran fine, right after water filled the hull, it would run at top speed then drop in rpms and the totally stop..then i had the probs that i have already listed..any othe suggestions
  9. #9
    Gold Coast Australia
    140
    Post
    Bills with the program, If you have more than 15.5 volts across the batt when you give the thing a rev, the reg/rec is sad.
  10. #10
    Jul 2002
    Morristown, NJ
    42
    Post
    A lot of water got in the hull? What happened next? Did you start the motor and suck that water inside? And like how much water is a lot? Up to the motor mounts or up to the carbs? Was the water properly removed from the hull (motor)? I'd start with compression check.
  1. 1995 Seadoo GTX will not start easily
    By pappaloo in forum Sea-Doo
    Last Post: 06-26-2007, 09:23 PM
  2. Replies: 8
    Last Post: 04-18-2006, 12:16 AM
  3. Ski Won't Start
    By GreenLanternLCD in forum Yamaha
    Last Post: 08-12-2005, 09:07 PM
  4. SL 750 Warm Engine -No Start
    By dierdorf in forum Polaris
    Last Post: 05-29-2005, 04:23 PM
  5. Replies: 17
    Last Post: 12-22-2004, 12:54 PM
