New SBT 4 stroke Motor and New Oil pump all new gas, oil filter and spark plugs. Motor idle just perfect,and Gauge working just fine. No problem with wiring harness, Check oil pressure at idle 70psi. New oil pressure switch, and have even tried new wire from switch to ECU. My problems is NO UPPER RPM because of Oil pressure indicator signal, I am stuck in limp mode. Tried new ECU because Kawasaki Diagnostic software will not communicate, but yet the Diagnostic software work just fine on the other 2005, 2003 STX f12/15 we have at the shop. Any suggestion call me at JetSkiDoc LLC (252) 633-3611.
2006 Kawasaki STX 12F ( False Oil signal indicator)
Re: 2006 Kawasaki STX 12F ( False Oil signal indicator)
sounds like an electrical issue in the harness, if you have tried 2 different ecu's and none communicate with the diagnostic software then look more towards the harnessSBT Tech Support is here to help with your problems.
