I recently perchased a Polaris 780 and a 900. In an attempt to start the 900 I used a jump starter and smoked the CDI module on the 900. I have bought a new module, but did not remember where the brown wire connected to the cercuit board. The module has only two wires that connect to the PC board. one is black with a yellow stripe and is clearly marked on the PC board. The other wire is a little longer and is brown, but the PC board has no place for a brown wire. I need to know what terminal the brown wire connects to.
After looking at several other modules I have found that on all the other modules the wire is gray. Does this wire connect to the gray terminal on the PC board?
I have also noticed that someone has jumpered the pink wire to ground. Can you think of why anyone would need to jump the pink to ground? This wire seems to feed the guage, regulator and fuel guage.
I also read on your blog that the SL900's had an issue with bad stators. My module is part number #4060180. Is this the good or the bad module and stator.
Please help if you can, I don't want to burn out another module.
