Results 1 to 3 of 3
  1. #1
    Joined
    Jun 2011
    From
    Tarpon Springs
    Posts
    18
    Default 2004 Honda F12 engine installation question.
    I purchased a rebuilt 2004 F12 engine last week from you folks and am putting it back together. When installing the crankcase cover the manual specifies 3 Joint Pipes (see attached picture). When I took the motor apart I was very careful to place every part/bolt into categorized ziploc bags, and I only have one Joint Pipe. I took pictures of the engine before sending to SBT, and I clearly did not leave any Joint Pipes in any of the passages. Also, the one Joint Pipe I have will only fit into the center passage on the block, the two outer passages are too small and not machined with a deeper cut to accept the Joint Pipe in the same way the center one is cut.
    Do you know if three Joint Pipes are used in all 2004 F12 engines or are there some versions that only use one Joint Pipe?
    I hope the image works, the only way I could think of attaching a URL was using Facebook.
    Thanks,
    Gary Antonellis (727-415-4444)
    Honda Manual | Facebook
  2. #2
    Joined
    Mar 2003
    From
    SBT
    Posts
    21,545
    Default Re: 2004 Honda F12 engine installation question.
    Not all the engines have the 3 pipes
  3. #3
    Joined
    Jun 2011
    From
    Tarpon Springs
    Posts
    18
    Thanks!
Thread Information
Users Browsing this Thread
Similar Threads
  1. 93 tigershark 640 engine installation question
    By jststrd1 in forum Tigershark
    Last Post: 08-06-2010, 09:52 AM
  2. Honda R-12X Flushing engine after use
    By 8kgold69 in forum Honda
    Last Post: 06-24-2009, 10:29 AM
  3. (2004) 4-stroke engine question:
    By Hednup2 in forum Polaris
    Last Post: 11-22-2008, 01:14 PM
  4. For Sale 2004 Honda F-12x
    By Boostedevo8 in forum PWC's For Sale
    Last Post: 07-14-2004, 12:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
