You could if you wanted to, but taking the water from the top of the head, like a stock watercraft, removes the air trapped in the head.
water line routing
Just want to double check on my cooling system. 720 MOTOR IN HX. The inlet line runs from the top of the pump through a filter (aftermarket) to the exhaust side of the motor correct? This line also tee's off prior to the head and runs over to the down stream side of a "Factory Pipe. Now the rear (carb side) of the head runs straight to the back of the ski? Also, is this a good point to tee into the line for a visual confirmation that water is running through the motor? Thanks
[ September 06, 2003, 02:08 AM: Message edited by: Stincee ]
