HX 720 ENGINE IGNITION TIMING
This topic is closed.
  • #16
    Re: HX 720 ENGINE IGNITION TIMING
    You set it with an Bombardier electronic programmer.
    • #17
      In my shop manual CD I found this:
      " 787 Engine - When reinstalling magneto rotor to engine flywheel,
      one of the protuberance end of magneto
      rotor must align with hole of engine flywheel. "
      • #18
        Nothing new there, it's already covered in our tech article on the subject...
        • #19
          Mestre,
          Yes, but that only sets the magneto in the correct position. It does not set your timing.
          • #20
            Correct me if I'm wrong, but doesn't that set the base timing then to set the ignition timing you have to use an electronic programmer? I'm still a little new at this and I took my magneto off the flywheel when striping the engine to send in to SBT. I couldn't find any markings to put it back on properly so that I know the timing is set back to where it was. I looked in my manual and thought I would post because Tech Support posted that there is no such adjustment.
            • #21
              First of all, the picture of the 787 magneto shouldn' have been posted in this thread regarding a 717 in the first place. Second, no there is no manual adjustment on a 787.
              If you guys want to talk about a 787 start a new thread. Closed.
