Bill and Tech what are your thoughts on the Below.
I just got my engine mounts yesterday. I went to my local Sea-doo/performance parts dealer and he had both OEM and Goki. They use OEM(by default and love them), but several of the racehead techs said if you have the money get Goki. So I did.
Most of the orginal under engine mount shims are pratically destroyed by corrosion. So they can't be used.
Could I mount the new engine mounts to the hull without the under engine mount shims?
And just use the shims that go under the engine support bracket and on top of the rubber engine mount for alignment purposes?
On the bolts use blue loctite 242, right?
Thank You
[ September 06, 2003, 12:42 PM: Message edited by: cobrajoe ]
Thank You
