Results 1 to 10 of 10
    Jun 2011
    Tarpon Springs
    18
    Default Knock sensor alarm on new SBT engine - 2004 Honda F12
    Just finished breaking in my new SBT engine and my FI alarm is going off with code 25 which indicates a "Knock Sensor circuit Malfunction".
    Here is some additional info:
    - Ran motor about 8 hours before the first alarm went off. No problem during break-in or for the first few hours of normal operations.
    - I can run it the next morning half an hour or so before the alarm goes off
    - If I disconnect the harness long enough for the display to time out. I can then restart it an run another 10-15 minutes before the alarm comes on.
    - The longer I let it sit after alarm, the longer it will run. As if cooling off seems to help.
    - I bought 30 gallons of 93 octane, this batch was used during breakin and for a few hours of normal running without the FI error, so I think the fuel is not the cause.
    - I never had this error on the old engine where the sensor originally came from. Granted I could have damaged it during transfer....
    I am going to order a new knock sensor, but are there other likely causes?
    Am I risking engine damage to run it until the knock sensor goes off, then the 1/4 mile back to the dock while the FI alarm is beeping?
    21,545
    Default Re: Knock sensor alarm on new SBT engine - 2004 Honda F12
    pre ignition will cause the sensor to trip, if the sensor is bad I would think it would be going off all the time. Put some octane boost in the tank, see if that helps.
    Jul 2011
    upstate, SC
    3
    I just had the same problem with a knock sensor code 25. The unit was an 02 f12x. It had an all original engine with 134hrs. Replaced the sensor and 3 hes runtime later the wristpin on number 4 broke....at 6k rpm. Not saying that's what is wrong w yours but I would do a rod end play check to verify the sensor isn't picking up a rod knock. good luck
    Jun 2011
    Tarpon Springs
    18
    very interesting because I am starting to worry it is the motor. This is what I have done/observed since then:
    - Added octane booster, it was fresh 93 octane if Shell is trustworthy. This had no impact.
    - Removed the pump coupler so that any bearing vibration from pump would be eliminated. This had no impact.
    - The sensor is going off sooner each time I start the engine, it now goes off within 5 minutes of run time.
    - The temp light was flashing this time along with FI light, the alarm code was still 25 (knock sensor)
    - When I first installed the engine it was smooth as silk at 5000 rpm, now it feels rough.
    Jul 2011
    upstate, SC
    3
    Is the engine getting hot? Check your cooling lines for blockage, verify a good flow of water at the indicator on the rear port side. Also a misfiring spark plug can cause the knock sensor to trip. I'm sure you know those plugs are expensive but I would rreplace them anyway.
    Jun 2011
    Tarpon Springs
    18
    When running from a hose got lots of water coming from the exhaust and the telltale stream looks normal. Plugs are new, replaced them with the motor. I have checked the plugs (multiple times now!) and all plugs look the same and they look good. Don't see any difference between cylinders.
    Thanks!
    Jul 2011
    upstate, SC
    3
    Why did the original engine need to be replaced? What was the cause of failure? Were there any other codes showing or just the knock sensor?
  8. #8
    Jun 2011
    Tarpon Springs
    18
    Well after replacing knock sensor and eliminated the coils, spark plugs, fuel and jet pump, all fingers are pointing towards a bad ECU. Had Honda dealer put it on computer and that is their conclusion also. Hopefully I can find a good used one because the best price I can find is $750
  9. #9
    Jun 2011
    Tarpon Springs
    18
    Well I found a used ECU from 2007 F12 and it is running great, I am actually getting an extra 2 mph, cant explain why but I will take it! And I learned that the knock sensor alarm is a common symptom of a bad ECU.
    Tom, I want to thank you and the folks at SBT for going the extra mile to help me. Without going into details, SBT has proved to be a customer focused company that others could learn from. Often times the market leader gets arrogant and complacent, great to see that has not happened with you folks!
    Many Thanks!
  10. #10
    21,545
    Gary, it good to hear its working well, we are always glad to help.
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. Replies: 2
    Last Post: 06-30-2011, 12:55 PM
  2. For Sale 2004 Honda F-12x
    By Boostedevo8 in forum PWC's For Sale
    Last Post: 07-14-2004, 12:52 AM
  3. engine knock
    By squared in forum Polaris
    Last Post: 06-28-2003, 01:37 PM
  4. 951 Engine knock
    By Bernie V in forum Sea-Doo
    Last Post: 06-20-2003, 10:15 PM
  5. engine knock
    By Rodney Leopard in forum Sea-Doo
    Last Post: 04-22-2003, 11:34 AM
