I have a 2006 GP1300R fuel injected non power valve. I wanted to install a D Plate to eleminate the cat. I was advised that if I want to install a D plate, because it is a fuel injected unit without the power valve system, that I would need to purchase a RIVA EFI Control module from RIVA. Without the control module the engine will run to lean and cause the engine to eventually seize. True or false?
The control module is $380.00. If true, I will just leave the cat in it.
Please let me know the facts on this issue.
