My polaris 1200 slx Won't go Over 15mph. ????
  • My polaris 1200 slx Won't go Over 15mph. ????
    So i have replaced the pump and the impeller any ideas???
    Re: My polaris 1200 slx Won't go Over 15mph. ????
    Need more info to help you, Does it rev up and not go? or does the engine bogg down and not build rpms?
      I went and ran it today. It ran ok. but not great after about twents mins. I let it rest got back on it and again only 15 mph. it revs up and goes nowhere.
        Could be drive shaft splines are toast, impeller splines toast, crank coupler is shot or wear ring and impeller clearance is to great.
          what are the splines
          and how much roughly to replace
            Taken the drive shaft out and inspect the ends for damage. Check to inside of the impeller for damaged splines and the crank coupler too
              do you need a special tool to take out the impeller??
                Yes, Call SBT we sell them.
                  Is it possible that it could be an over heating sensor.
                    If the ski revs up to 6500 rpm but just doesnt go over 15 mph then no, over heat should make it misfire, hit the revlimiter instantly.
                      Actually it sounds exactly like it is misfiring now that you mention it. It starts out normally then at about 15mph it starts misfiring and slows down to about 5mph with a constant misfire if my finger is on the throttle.
                        Un plug the gray wire in the electrical box and see what happens, that will disconnect the rev-limiter.
                          Ok so i took out my jet skis today and both ran very well. Until I got my 1200 slx home and was flushing the engine. It started that misfire crap again. so I should disconnect The gray wire and see what happens??? And I know this is off that subject, but my other 96' sl 780 had tons of water in it after only three hours in the lake . Any Ideas on that?? And the plug is fine and was in.
                            Disconnect the gray, see what happens and check the driveshaft seal, its probably leaking.
