crankshaft 900 ZXI
  • crankshaft 900 ZXI
    Hello all i´m new here so i thought let´s start with a question.
    Can a 1100 ZXI crankshaft be used on a 900 ZXI engine ,the crankcases are the same and the crankshaft looks the same too but i´m not sure.
    Re: crankshaft 900 ZXI
    Both the 1100 and 900 are different, cases and cranks.
      Can you describe the difference? Everyone is telling me they are different, but no one can tell me how. If someone could put this to bed I would appreciate it. Thanks
        Click image for larger version
Name:	Kawasaki 900 crankcase.jpg
        The space between cylinders is different.
        Approx. 19mm = 1100cc.
        Approx. 36mm = 900cc.
        1100 cases all have 2 pulse fitting for carburetors.
        900 cases some have 1 pulse fitting and some have 2 pulse fittings.
        Crankshafts use the same pins, webs, etc., but have different length rods.
