Results 1 to 5 of 5
    Aug 2011
    Ventura County, CA
    6
    Default What is a equivalaent approved motor oil for a 2005 GTX SC motor?
    According to the 2005 operators guide, it states to "Use the XP-S 10W-40 4-stroke oil (P/N 219 700 346) or an equivalent approved by BRP" So my question is what is a approved equivalent 10w-40 motor oil that can be purchased at a lower cost?
    Aug 2004
    Olympia, WA
    3,629
    Default Re: What is a equivalaent approved motor oil for a 2005 GTX SC motor?
    BRP oil is of course the recommended oil, but...Any mineral based (non synthetic) 10w-40 will work fine. I prefer Castrol, since that is what BRP oils are formulated from.
    DO NOT RUN ANY SYNTHETIC OIL IN A SC MACHINE.. Unless you have the 08' metal washer update done. The ceramic washers were prone to slippage when synthetic oils were used.
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
    Aug 2002
    Hartford, WI
    84
    I think Amsoil has the right oil that has the JASO specification the wet clutches need
    Red 03 GTX SC and Yellow 03 GTX SC
    Aug 2002
    Hartford, WI
    84
    Aug 2004
    Olympia, WA
    3,629
    Yes, amsoil has always stated that their oils will not make the ceramic clutches slip. That being said, if you use it and it does slip or break, any chance at warranty is out the door.
    Dan Solie -
  1. Replies: 5
    Last Post: 11-20-2008, 01:31 PM
  2. Sea doo XP Motor Hard to start New SBT motor
    By lvnspeed in forum Sea-Doo
    Last Post: 03-10-2006, 12:26 AM
  3. 787 Rotax Motor Rebuilt the top end but motor wont start
    By info@resilicon.com in forum Sea-Doo
    Last Post: 09-02-2005, 07:32 PM
  4. yellow 580 motor vs white 580 motor
    By Mark aka importeater5.0gt in forum Sea-Doo
    Last Post: 09-09-2001, 02:37 PM
