1100 STX Pump Into A 900 STX Swap?
  • 1100 STX Pump Into A 900 STX Swap?
    I have a perfect jet pump out of a 1997 1100 STX that I would like to swap onto a 1999 900 STX. The pump in the 99 works but its pretty corroded from the PO leaving it docked for weeks at a time. I know the mounting bolts are a smaller diameter on the 900 stuff but is there any other difference? Thanks...
    Re: 1100 STX Pump Into A 900 STX Swap?
    If the 900 was an 01-02 stx it would work, the 900 housing is different and I think the impeller is smaller on yours, verses the 1100.
