2002 polaris virage txi
  • 2002 polaris virage txi
    darn thing will only run as long as you hold the start button, soon as you let go it dies !!! whats up with that ??? any ideas ?
    Re: 2002 polaris virage txi
    start/stop controller part # 4010669 could have gone bad.
      replaced the controller, same thing happens
        Trace the wires from the button down to the controller, maybe its the wiring.
          ok well now it acts like it wants to run but wont, installed new plugs checked voltage to injectors white/red stripe even pinched return fuel line trying to increase fuel pressure even though it has 20psi on return line
            You may end up sending the ecu (computer) off to D.F.I tech for an inspection. 1866-298-1510
