SBT replacement through hull fittings for drive line?
  • SBT replacement through hull fittings for drive line?
    what material is the replacement through hull fittings for the drive shafts/bellows for the challenger 1800 jet boat? Aluminum? Brass? Bronze? I can`t seem to find whsat they are made from, unless I just missed something. Thanks...PR...
    1998 SeaDoo Challenger 1800
    sigpic
    Re: SBT replacement through hull fittings for drive line?
    Its nice to hear from the Pale Rider, Aluminum and anodized a goldish color.
      Thanks! I will add this to the list!, Cool, anodized for metal/corrosion protection!
      Is there a recommended epoxy for installing this part?
      Thanks again!
      sigpic
        Good Morning Tech, can you please provide part number the the Anodized thru hull fittings for the 1998 Challenger 1800 boat? and what epoxy is recommended? also will the SBT`s (new) engine alignment tool work with the boat? in stock as well?
        thank you...PR...
        sigpic
          Andy, the alignment tool will work and I like using West Systems epoxy with capisil to thicken up the material. The thru hull fitting is 76-101A-07
            Thank you!
            sigpic
              The additive to thicken is not here locally. I have used Marine tex in the past and hope this is just as good...
              sigpic
                That should work too.
