1996 SL900 hard start after sitting
  • 1996 SL900 hard start after sitting
    Since last summer, I have had an extremely hard time starting my SL900. It almost seems as thought a fuel check valve has gone bad.
    If it has been sitting for more than a couple days I have to crank for about 10 seconds 3-4 times in order to get the ski running. I will get an initial fire immediately, then nothing for quite awhile.
    After the ski finally starts it is good to go until it sits again.
    Is there a fuel check valve in the system somewhere, or are the diaphragms just getting weak?
    Thanks, Cory
    Re: 1996 SL900 hard start after sitting
    There are 2 check valves on the fuel tank, 1 lets psi in and 1 lets psi out if too much builds up. The tank must hold 1.5 positive pressure. Sometimes the water seperator/filter can leak air causing air to enter into the fuel sustem, try running a fuel line direct from the tank to the carbs and see if the issue goes away.
      Excellent, thanks.
