I just replaced the old engine with a reman SBT premium engine and had the carbs rebuilt at the same time. I did not write down where i pulled the fuel lines from and had one extra without a home when I hooked them back up? I then went step by step in my Clymer manual and all did not match with what I had in place. In the Clymer manual page 179, figure 9, item B. I had a 3" hose plugging that connection off. By the book, the hose that was supposed to go here was on the male nipple above that one, the (return line). What I did was by the book, I took off the Plug that was in place and installed the fuel pressure line to this connection, and on the fuel return above I connected the return line going back to the tank. It did start briefly after using a primer bulb to get gas from the tank to the carbs. but once it burnt that gas out she would not start. Please Help! Send pictures, e-mails or smoke signals!!
Thanks in advance,
Mark Todd
Thanks in advance,
Mark Todd
