1996 900 STX blowing 2 cycle oil out the exhaust
  • 1996 900 STX blowing 2 cycle oil out the exhaust
    Hi,
    Wondering if anyone has had this problem before. I have a 96 900stx that has not been started for about a year and a half and today we put in a new battery to get it going and after a few min it started and was blowing alot of smoke which I was used to from before, but the smoke continued after about 5 min. What I was noticing was 2 cyl oil coming out of the exhaust. I thought because it was sitting so long it was because of that. But it kept coming out after the 5 min so I stopped running it thinking maybe something happened to the oil pump. I have heard of them blowing up because of them not putting out too much oil, but this is putting out way too much for sure.
    David
    Re: 1996 900 STX blowing 2 cycle oil out the exhaust
    You may have had oil and fuel sitting in the exhaust and the crank case for sometime and thats what was coming out, run it for a few hours and see if it clears up.
      Thank you for your Help. I will do that.
      David
