Virage carb tuning
  • Virage carb tuning
    Just received my carb kit and a few other parts for my '01 virage 700. Great prices and fast shipping as always. I have two questions, 1) what are the baseline needle settings, and 2) any input on which needle spring is typically closest to factory?
    Re: Virage carb tuning
    Your low speed should be around 1-1/8, use the original spring that was in the carb.
      thank you for the quick reply. I matched the medium spring in the kit to the original and used it. still have the original thoigh. do you happen to know the high speed setting? It was about 11/2 out before the rebuild.thanks again.
        Try 1-1/4 to 1-1/2 on the high and install the original spring.
