Hi. I just installed an SBT long block in my 2001 tx and screwed up as I didn't mark some of the fuel lines as to their connections. The two lines I do not know the connections for come off the carburator tops on the two end carbs. They point towards the back of the ski and are about 1/4 inch in diameter. I looked up the fuel line schematic on http://partsfinder.onlinemicrofiche.com/ and found the line to be labeled as #7, but the schematic does not show their termination points. Help! Thanks!
Virage tx fuel ine routing
Re: Virage tx fuel ine routing
They are pulse lines and go to the crank case nipples below the reed cages. They feed pulse to the fuel pumpsSBT Tech Support is here to help with your problems.
