New eng fro SBT run great for about 10 hrs after breaking. The problem is sometimes hard to start & it will plane but will not go over 30mph unless it hit a wave and go airborne. then will go up to 65 is like it hit overdrive. I love this sky but i will like to have a smooth transition from 0 to 65 any IDEAS [img]/graemlins/angryfire.gif[/img]
97 xp aceleration problem
How long have you been running with them on and the incorrect jets? If more than a few WOT passes you have probably already damaged your engine. Take a compression check right now.
Get the proper jet kit from www.watercraftmagic.com - you have been running way too lean because you put on less restrictive filters and did not add the additional fuel needed.SBT Tech Support is here to help with your problems.
