Hellow i have a 1995 polaris slt 750 that was blown up bent rod nuber 3 cly dont know why the exhaust crossover rubber pipe had blisters in it also know termostat in cooling rail just pop off valve present also is there suppose to be an orfice in the fuel line should i block off oil pump and premix changing out blown motor with 650 short block that was rebuild also got some carbs from a 780 sbt said they are better carbs can i just bolt them on and install a high out put fuelpumo tanks if you can help me out here
slt 750 1995 polaris
Re: slt 750 1995 polaris
The 780 fuel pump will work well. Pre-mix will work great, go 40:1 and block off the oil feed line to the pump, install the block off plate and block off the nipples that had been feed by the oil pump.SBT Tech Support is here to help with your problems.
