Results 1 to 8 of 8
    Dec 2008
    34
    Angry Tech Support help with lean condition
    Recently installed 2nd SBT 1200PV engine, new reeds and plugs in my Y2K GP1200R. Previous SBT engine failed due to rear cylinder burn out. After 2-3 hours of break-in riding I pulled the plugs and now the front cylinder is showing a lean condition. Was very careful to install the intake manifold and carb
    assembly following OEM recommendations for torque and tightening order so I don't suspect an intake leak. On the previous engine, the plugs were showing front cylinder rich, middle perfect, rear lean. What do you recommend?
    21,545
    Default Re: Tech Support help with lean condition
    Does it have the cat installed? Had the carbs been rebuilt and what did you set the pop-off psi to?
    Dec 2008
    34
    Quote Originally Posted by Technical Support View Post
    No cat, RIVA DPlate + Chip and freeflow exhaust, stock airbox. Carbs were rebuilt when I installed the previous SBT engine. I did not measure pop-off as I
    didn't have the proper tools. Curious how I can go from the previous condition of front=rich, middle=perfect, rear=lean to front=lean, middle and
    rear look OK. I did not rebuild the carbs again. All that has changed is the engine. Thanks.
    Dec 2008
    34
    Quote Originally Posted by SMLAKER View Post
    AND a new set of reeds from SBT.
    21,545
    Go back through the carbs and check pop-off too. 65 psi is what you want.
    Dec 2008
    34
    Will do. However, I have the RIVA D-Plate & chip. I plan to remove the stock air box and install RIVA FAs/socks/splashguard. I will be looking for a PO around 50-55 to keep it a little richer.
    21,545
    Correct, lower pop-off for aftermarket filters
  8. #8
    Dec 2008
    34
    After the mods, I also plan to disable the accelerator pump as that will add too much fuel to 1&3
  1. lean condition in 720 seadoo
    By Snipescastle2 in forum Sea-Doo
    Last Post: 03-29-2010, 06:48 AM
  2. Replies: 15
    Last Post: 04-09-2005, 06:44 PM
  3. SBN Mikuni carb lean condition
    By itsmarta in forum Sea-Doo
    Last Post: 09-17-2004, 03:08 PM
  4. 85 JS550 Lean Condition
    By dhym in forum Kawasaki
    Last Post: 09-03-2004, 09:27 PM
