I have a 1994 Seadoo Bombardier GTX with a 657 Rotax engine. It was making noise in the bottom end of the engine but ran good. I purchased an SBT reman engine and installed it. it starts up and runs fine out of water, in the water it starts up and runs good but has no power will only go about 5 MPH since the new engine was installed. I also put a new wear ring in the jet pump. I have a shop manual and set the rotary valve timing with a new 147deg valve according to the manual. It is my wife's jet ski and she removed the old engine and I installed it. When she removed the Flywheel she damaged the stator and I replaced it with a used one. I lined up the marks on it and the housing. I am pretty confident that both timings are correct. I am a newbie to jet skis, but spent the better part of my life as a Heavy Equipment Mechanic. For some reason I am thinking that it might have a fuel issue. Anyone have any ideas on possible other causes for the low power issue on a newly installed engine?
1994 Seadoo GTX new SBT reman engine has no power
Re: 1994 Seadoo GTX new SBT reman engine has no power
Rebuild the carb and replace all the fuel lines, clean the selector valve and see how it runs.SBT Tech Support is here to help with your problems.
Sounds good, 90% of all watercraft engine failures are from dirty or damaged fuel systems.SBT Tech Support is here to help with your problems.
