What should the recommended jetting be for a starting point for a psi pipe and westcoast waterbox for a 1992 sl 650???. The stock jetting is # 80 pilot and # 80 main. I only find info on the triple pipes for sl polaris watercrafts I have fiber reeds/spacers and also a open air filter off of a slx 780 with fuel logs off of a slx 780 and triple outlet pump for updated fuel system. Removed choke and installed a primer kit. Also mild port /blending on cylinders.
Polaris PSI Pipe jetting
Re: Polaris PSI Pipe jetting
Thats an after market pipe that wasn't too popular, my best advise is to search over on green hulks web site in the polaris area, 785 lugs or beerdart may have the jetting specs, both these guys deal with a ton of old polaris parts.SBT Tech Support is here to help with your problems.
