Hi, I have a RTX 2005 with about 110hrs on it (never had issues before)...I was out yesterday for about 30 min. riding at 1/2 power or less then the last 5 min to get back in I was at full power at 70mph, as I let off the power to approach the lift I lost #3 cylinder I ended up coming in on 2 cylinders....I felt by a very light smell the engine was hot, I felt around inside and did feel a bit hot but nothing serious, I let it cool down a bit and the third cylinder started to fire but went on and off, I then pulled plug on #3 and #2 compared and found nothing wrong with spark plugs, I swapped plugs from #2 to #3 and coils, started it back up let it idle and #3 was missing less but missed every 5 sec or so, also after doing the spark plug swap, it was even more cooled off as to why maybe it was missing less or working better....
I’m feeling it was an over heat issue? if so, why, and how to trouble shoot this overheat issue?
I did notice that once I brought it in on 2 cylinders, I lifted it out of the water, then put it back to idle it, I noticed bubbles coming from back of seadoo once I put it back into the water, like the heat exchanger was boiling the lake water, I just never noticed anything like that before (bubbles).
