Hey guys,
I just gave my first try on an engine rebuild - and it fail! The engine broke after just 1.3 hrs...
After rebuild i had 145psi on both cylinders. Rebuilt the carbs too. The one of #2 was very dirty and I wasn't able to loose the needle seat, without destroying the screw - so I let it in it's place.
It started just with useing the primer, thought it's the idle rpm I hadn't adjusted, yet. I noticed already that the cylinder #2 run a bit to lean, so I stopped the first day after 0,75 hrs break in. Proofed the carb settings and switched from riva air filters back to the original one, to get it running richer.
Gave it another try for about 10-20min... it sounded way to rich and was running bad. I decided to stopp again.
Back home I took off the exhaust again to check everything. I adjusted the carbs again and increased the idle speed. Gave it a try... it started but sounded bad.
I checked the compression angain: #1=120psi #2= almost 0
I don't know what I did wrong!
I choosed the right fuel mixture 1:32
I was even driving carefully cause of breaking in.
I thought already that the carburetor of #2 is just broken... but on the other hand, I replaced all parts. Even if the needle would be blocking in the seat (I couldn't remove) it should have just run to rich, or am I wrong?
This night I thought about my crankshaft seals... could it be possible that I mixed 'em up?
I orientated to those of the crank I replaced. (just bought the ski)
If I'm right, you just can place them at one spot - theya will fit just in one way. Or don't they?
What about my outer crank seal at coupler - is it right, the way it's placed?
Or did I do it wrong and produced an air leak?
Thanks already forwarding for your help!!!
