Hi,
I have a 2000 Yamaha SUV 1200 non power valve with 152 hours on the clock and no compression in the aft most cylinder. We pulled the engine and are weighing options as to what to do next (the SBT instructions are awesome). The most popular option is to buy the SBT 1200 long block.
I have some questions that I hope you can help me with:
Thanks in advance,
Dave
- #3 piston failed (melted) on the exhaust side. Oil lines were connected. What caused this to happen?
- Is the PTO flywheel threaded? If yes, is it "lefty loosey"? I have tugged on it couple times and it is being stubborn.
- The starter motor came off, leaving the end cap at the bell housing side still attached. I dont see a snap ring and I have pried at it some without much result. I see a roller bearing in there. Is this press fit? and if so, do I need to pound it out to replace the starter?
- Do you have any promotions or discounts planned between now and spring? I am always looking for a bargin.
Thanks in advance,
Dave
