2005 SeaDoo 3D -
I have an overheating problem and am going through the cooling hoses cleaning them out and making sure they are clear.
I'm doing a combination of checking for cracks,flushing & blowing air.
When I got to the Anti-Rollover Hose the top elbow joint was blocked (indicated in graphic) the water flow is indicated as coming from that elbow and into the lower one. When I removed the elbow joint there was a load of crud in the elbow and the opening, which I cleaned out.
If I blow air into the bottom elbow it flows freely, (as do all the other hoses), yet when doing the same with the top elbow it doesn't flow at all -I just want to make sure that this is correct perhaps due to the manner that the anti-rollover hose functions or if it is possibly part of my overheating problem??
Thanks for any help or advice
