I have a 2002 Yamaha FX140 with a 2003 replacement motor in it. I'm using the 2002 fuel injection and ECU that came with the machine. I went to start it for the first time tonight after installing the 2003 engine and noticed that 3 cylinder ports were filled with gas so I removed the gas from each port and hit start again and it cranked a few times but the fuel injection kicked on and filled them up again. Any help would be much appreciated !
Yamaha FX140 filling cylinders up with gas
Re: Yamaha FX140 filling cylinders up with gas
Had same problem. Turns out the injectors are activated from a ground circuit in the computer. I replaced the injector with a know good1 first and did not fix it. New computer fixed it. 1 injector circuit in my compurer was shorted. Check your grounds.
Thanks that helps a lot. I will measure the injector grounds first to see if that is working properly. I think it turned all four injectors on. I had cylinders full of gas and ports that filled up it was crazy !
