I recently purchased a remanufactured crank from you guys and see you have switched from japanese to chinese bearings. The crank I am replacing is from one of your remanufactured engines, yamaha xlt800, I purchased some years ago. The crank has lasted through several topend failures thru the years (wrist pin circlip failure, couple of ring snag issues and another dropped power valve)but the crankshaft held in there until the rod bearing cage lost some peices and nicked up the pto cylinder wall. The questions I have is did you guys use different bearing suppliers for crankshafts used in your remanufacted engines sold than the remanufactured crankshafts sold? If they were the same then why the switch to different bearings? Am I installing an inferior or lower quality crank?
crankshaft bearings
