new sbt 155mm liner wear ring loose as falls st8 through
  • new sbt 155mm liner wear ring loose as falls st8 through
    new sbt 155mm yamaha wearing and housing the liner is loose slides in and out and all around? it's not tight at all i can see it just spinning in the housing?
    thought they where meant to be a press fit?
    the 144mm housings i got the liner is a little tighter and at least grabs the housing whats the story sbt?
    cheers
    Re: new sbt 155mm liner wear ring loose as falls st8 through
    The liner is more loose in the yamaha's than in the seadoo's.
    The impeller housing (housing 1) with the liner in it gets sandwiched between the Stator housing and the forward housing (housing 2). When it is bolted down the wear ring will not spin in the housing.
      Exactly what I needed to know. Thx
