96 sl 700 CDI ISSUE?
  • 96 sl 700 CDI ISSUE?
    i have a 1996 sl700 just did a top end kit and when i went to fire it up i had no spark i checked the stator, battery, coil, im going to check the triggers but worse case senario looks like ill have to do the upgrade
    my question is has anyone done this upgrade and will it give you any benefit (besides a working ski) or should i just find a good used/NOS CDI?
    also someone said they can test my CDI for $30 working or not, is there a way i can test the CDI or is this a sham?
    thanks for any and all input
    Re: 96 sl 700 CDI ISSUE?
    just an update i found out the old CDI's usaly go bad 90% of the time so i installed an MSD igintion kit and it works great used the old stator and just adjusted the timing havent tryed it on the water yet but cant wait
