Need help diagnosing a problem with my 99 STX 900
  • Need help diagnosing a problem with my 99 STX 900
    It will start and idle just fine but as soon as I hit the throttle it bogs down and will not accelerate (neither in the water nor on the hose)
    It ran fine a week prior to developing this problem.
    Carbs are in good shape and I actually swapped them out with the carbs from another STX 900 that is running correctly and the problem persisted.
    Did a compression test and each cylinder is right at 100psi.
    I opened the e-box and there are no signs of corrosion or lose wires.
    I replaced the plugs and removed the plug wire ends and cut the wires back about 1/4in, cleaned them and reinstalled.
    The digital multifunction meter doesn’t work, but it hasn’t worked for a while now so I doubt it has anything to do with this problem.
    Where do I go from here?
    Re: Need help diagnosing a problem with my 99 STX 900
    Here is a quick video of what its doing…
    https://www.youtube.com/watch?v=9njIqN4F9_8
    I also took off the carbs and intake and checked the reeds… they look good.
    And I tried disconnecting the ambient air sensor and exhaust sensor and there was no difference.
      Did you ever figure this out? I had similar issues.
        When's the last time the carbs where rebuilt and the fuel system serviced ?
