I have a 1989 Kawasaki JS550 Jetski with West Coast exhaust manifold and pipe. I am trying to determine what the correct routing would be for the water lines. Any thoughts or suggestions where I might find a picture of the correct line setup? Thanks for any suggestions.
Kawasaki JS550 Cooling Line Routing
Re: Kawasaki JS550 Cooling Line Routing
So I did not get any replies to my question, so here is what I did for cooling line routing. Line from the pump is connected to the exhaust manifold. Line from the front side of the head is connected to the exhaust elbow. Line coming out of the lower side of the exhaust elbow is connect to the fitting at the end of the exhaust pipe just before the hose that connects the exhaust pipe to the water box. There is also a tee in this hose that is connected to the fitting on the hull that indicates water flow. Thoughts??
