2001 Kawasaki Ultra 150 Sprag Clutch
  • 2001 Kawasaki Ultra 150 Sprag Clutch
    So i just recently installed a new engine from SBT in my ski and on initial start up i heard a slight whining noise. ( i did check that the gear free spun before i closed up the front crank cover) so i hit the kill switch and tried to start again only hearing a clicking coming from the solenoid. i tried to turn the engine over with one hand on the PTO coupler and one on the starter and i could feel that the starter had failed ( crunching , it was obviously toast) the starter that was installed was a cheapy from amazon. so the question is. do you think it was just a cheap starter? ill be buying a Venom starter the next go around. and does any one have an exploded illustration of how the sprag bearing, gear and washers /spacers are installed on the crankshaft?
