the water can be coming in many different places,could be a broken hose,the drive line seal,the thru hull fittings,you will have to inspect those areas
1) I too have water coming into the hull of my gsxl at the PTO at the carbone ring. Boot has no tears in it. When docked, I can manually spin the boot in a position where the water stops coming in, kind of an inconvenience each time you stop the ski though. Is there something I can replace or is my issue related to drive shaft alignment due to improper engine mounting?
2) I just replaced the broken OEM bilge pump with a new one (same model). It presently cycles when you tap the start stop button without the lanyard in. Does this bilge operate automatically if it senses water when the craft is off without the lanyard?
