HI.
I have a Seadoo Speedster 1998 with 787 two stroke SBT engines which start up first time from cold and run great and continue to perform well until I shut down the engines for about 5 minutes and then restart.
Both engines again start first time without any issues but when I get to about 1/4 throttle the left engine bogs down and doesn't want to rev any higher or cuts out and stops.(restarts up again first time) sometimes with a bit of throttle jiggling it will pull through and perform normally again I have tried pulling the choke a little when bogging but seems to make it worse. if the engine has been off for a half hour or so there isn't much of a problem.
Any Ideas or anybody has a solution would be greatly appreciated.
