Pop-off,needle settings
  • Pop-off,needle settings
    1995 Kaw 750 xi. Twin carbs. Stock motor
    What should the pop-off be set at?
    Can someone send me a link for that info?
    For the carb settings,the info I got is 3/4 turn out at low jet and 1 1/4 out for high jet to get started.
    Would that be for both carbs? I assumed 2 carb would be different.
    Re: Pop-off,needle settings
    It will be the same on both carbs. pop off set to 16-18 psi. specs here
