Results 1 to 2 of 2
    Jun 2016
    Sanford nc
    1
    Default 2000 stx di 1100 New SBT Starter , Flywheel not rotating
    Have my Stx that When I hit the starter button it will just zing.
    Things that I have checked
    pulled Plugs to make engine turn over by Hand.
    pulled the crank sensor rotating engine you can see movement like it should be
    pulled cover off top of engine to turn motor over
    removed starter using camera to see inside, when turning motor over by hand flywheel is not moving.
    this is a very nice & clean Ski with only 97 hours on it .
    I have checked and tried everything I can think of Any Help will make my Day
    Apr 2013
    Florida
    13
    Default Re: 2000 stx di 1100 New SBT Starter , Flywheel not rotating
    I would pull the front of the engine apart and check for a sheared flywheel key way or a broken crankshaft.
  1. flywheel starter gear 96 760
    By HRGreene in forum Yamaha
    Last Post: 09-15-2009, 09:50 AM
  2. Flywheel alignmet 99 GTX-RFI starter
    By TX21 in forum Sea-Doo
    Last Post: 10-08-2005, 10:45 PM
  3. flywheel / starter
    By linuxman in forum Sea-Doo
    Last Post: 05-25-2004, 04:05 PM
  4. starter/flywheel
    By bustedseadoo in forum Sea-Doo
    Last Post: 02-07-2004, 01:30 PM
  5. Flywheel and starter
    By Mike_121 in forum Tigershark
    Last Post: 10-09-2001, 10:39 PM
