If it's not one thing it's another...
After re-installing the jet pump, I took the ski down to the river. While the ski was still on the trailer and not started, I could see water trickling in from the four bolts that hold the jet pump to the shoe(?). Also, it looked as if a little bit of water was also trickling in from the where the engine water drain leaves the hull and from where the steering cable leaves the hull, on the lower starboard side of the boat just above the lower starboard pump bolt.
I took the jet pump back off and plan to use some rubber gasket sealer to seal around the outside where the bolts meet the hull. I also plan to cover the inside where the bolts come through the hull with some gasket sealer as well.
Anybody know why this happens? It never did it before I removed the jet pump. Will the gasket sealer do the trick?
- Craig
- Craig
