recently i replaced a fuel baffle for my '96 GTX because the fuel meter stopped working. The GTX worked fine, for the next couple minutes, then it wouldnt go above 2000rpms (in the water.) So i took her out of the water, cut the ends of the fuel lines, and reattached them with new clamps (to make sure they were sealed.) I took her back out to the water, ran great for the whole 30 minutes or so that i was out, averaged a peak of 6770rpms. The next weekend, when i took her out on to the water...the same problem was back. I checked the lines that attach to the fuel baffle, and everything was tight.
okay..so i figured, maybe it was a coggled fuel line? Filter? checked them all...except the one in the carb, but everything else was fine. Pulled the plugs...they were REALLY dark black, and soaked in gas.
Any takers as to what might be wrong? I'm thinking of rebuilding the carbs for the heck of it. (hasn't ever been done) Is it possible for the carb screws to have turned loose on their own? nothing on the engine has ever been tampered with (except the rave valves being cleaned at the beginning of the season.)
thanks!
bob
[ August 20, 2002, 08:01 PM: Message edited by: bob ]
thanks!
bob
