2006 stx-12f pump bracket
  • 2006 stx-12f pump bracket
    Hello,
    I'm trying to remove the pump bracket (this is attached to the hull with sealant) I have the pump housing off and the grate removed. Is there any puller to this or is some other way. I have followed the service manual, but it does say how to remove it.
    Re: 2006 stx-12f pump bracket
    Do you mean 11051 11051-3763 BRACKET
    Click image for larger version
Name:	12f pump Capture.jpg
    Is it damaged? I wouldn't take it off unless you absolutely need to.
    They are ussually held on by bolts from the inside and some very strong adhesive/sealant.
      Wish I didn't have to. It has bolts wrung off and grate is broken.
        Finally got the bracket off and all the wrung off bolts remove. Now putting it back on. What is best sealant to use in place of the factory glue they used?
          Finally got the bracket off. It was really stuck on there. Now putting the bracket back in, what the best sealant to use in place of the factory stuff"
            THREE BOND TB1211,HT/RS,WHITE
            Kawasaki# 56019-120
            See it here.Liquid Gaskets | ThreeBond
            Description: RTV Silicone Liquid Gasket White
            250ºC, Application: Crankcases, Plenum Chamber, Head Gasket Sealing with Solid Gasket on Motorcycles, Watercraft, Snow Mobiles & ATV Engines.
