Results 1 to 7 of 7
    Feb 2017
    Michigan
    2
    Default Honda Cylinder Sleeve Boring Specs?
    I recently ordered a Honda cylinder sleeve 44-600 from SBT to replace a damaged sleeve. Since the stock sleeves are very thin, the block must be bored out to fit the SBT sleeve. However I can't find any recommended specs on how far it should be bored out to accept the new sleeve. either the bore size or the interference spec would be much appreciated.
    Does anyone have experience doing it on this ski?
    Jun 2016
    Clearwater, Florida
    278
    Default Re: Honda Cylinder Sleeve Boring Specs?
    Use a 0.003"-0.004" interference fit on the main portion of the sleeve and a 0.002"-0.003 interference fit on the flange portion of the sleeve.
    Just be careful the aluminum on these blocks tends to crack easily. Be sure to heat the engine block to about 425 degrees prior to inserting the sleeves.
    Feb 2017
    Michigan
    2
    Awesome, thanks so much!
    Jan 2018
    Bunbury
    5
    Hello, does this go the same for the Kawasaki STX12F Cylinder bank, as I have a SBT cast Iron liner to install?
    thanks.
    Jun 2016
    Clearwater, Florida
    278
    Yes.
    Jan 2018
    Bunbury
    5
    Thanks. So just to check, I have SBT pistons to install in the 3 remaining Nikasil coated cylinders and a 4th piston of same SBT type to fit into the Cast iron liner. Will that work or do need to get a different piston/rings for the CI liner?
    Oct 2020
    Toms river, nj usa
    1
    Default Sexy photo galleries, daily updated collections
    Hot galleries, thousands new daily.http://gayporncruiseholly.kanakox.com/?akira xxx home porn mvies old 70 s porn niki bella porn brittany kildow porn video nude prostate massages videos porn
  1. cylinder sleeve misalignment?
    By Pale Rider in forum Sea-Doo
    Last Post: 01-13-2015, 11:33 AM
  2. Cylinder boring in daytona
    By mtuned in forum Sea-Doo
    Last Post: 08-20-2010, 04:20 PM
  3. Cylinder sleeve installation
    By ehiebert in forum Sea-Doo
    Last Post: 04-11-2007, 06:43 PM
  4. Cylinder boring and RAVE valve clearance
    By Baja89 in forum Sea-Doo
    Last Post: 05-30-2004, 06:58 PM
  5. question about SBT cylinder sleeve
    By lasaucisse in forum Kawasaki
    Last Post: 09-28-2002, 05:54 PM
