Ski started missfiring, reduced power, pulled spark plug, electrode closed, piece of debris in plug.(#3)
Piston top looked normal, but cleaner than 1 and 2. Bore scope showed slight wear on power valve side, in the shape of the power valve. Pulled head and noticed that PV is missing. Now this is a SBT engine installed in 2011 ran great up until this happened. Pulled engine, took down the top end, no debris in the case seen. PV missing? Where is it, so if it had the clips and such why did the PV make contact with the piston? It's like the PV and most of its shaft just broke off?? Seems like the PV guide in the cylinder is worn more then the others.
And by some strange coincidence just exited through the exhaust.??
trying to decide how deep to go in the repair, cylinders, crank, etc. I suppose I should have pressure tested before I tore it down. Any thoughts would be appreciated. I can post pictures but not from this media.
