RX DI 951 Air Compressor Adjustment
  • RX DI 951 Air Compressor Adjustment
    Any one have a good idea how much air the piston driven compressor is supposed to produce? I'm trying to check air pressure, and i think I've got that covered, however, I've heard it's supposed to be around 90 psi or so. and also, is the small adjustment screw on top of this cap the adjustment screw? And by turning this in or out, give you different readings? I'm sure that there is a range that you are trying to stay within, but a good link to a free shop manual would really help. ThnxClick image for larger version
    Re: RX DI 951 Air Compressor Adjustment
    90 PSI minimum.
    SeaDoo Manuals - FREE PDF Download!
