Pistons on 00 951 di that I just purchased and the seller knew nothing about the ski has the 8788# is this the bore size and how do I know what size to replace them with because they are bad and. I want to get a top end kit from sbt forbit
951 di piston size
Re: 951 di piston size
The 951DI engine have a standard bore of 88MM.
To be precise Seadoo offered 87.91MM as standard and 88.16MM as an oversize.
You would need to measure pistons and bore to be certain of what you need.
Here is the top end kit.
Sea-Doo Top-End Kit 947 /951 DI RX /GTX /LRV /XP /Sport LE /3D 947 2000-2006: ShopSBT.com
