2001 GP800R Carb settings (pop off)
  • 2001 GP800R Carb settings (pop off)
    Totally confused here, in browsing the threads I see people state the stock pop off setting on this ski is around 75lbs, on the pdf file in the tech support section it says 45-55.
    Why the differences?
    This ski is bone stock with the exception of an aftermarket impeller, it has .25 over pistons installed.
    Got 2 rebuild kits on the way, just want to make sure it is set right since the carbs are so easy to remove.
    Thank you!
    Re: 2001 GP800R Carb settings (pop off)
    Anyone?
    Kits came in today from SBT, got the pump side ready, waiting on any input, I guess 75 being the stock number is what I'll go with!
      Spec book calls for a 1.2 needle and seat along with a gold spring which equals approximately 75PSI
        Thank you! Carbs are running 85-90 right now with black spring and "shiny" silver spring from kit, the other 2 (silver) give me about 50 and 40.
        Guess I'll work on trimming springs tomorrow!
        Thanks again.
